BIM
Enscape Real-Time Rendering - New for BricsCAD BIM V20
Przez Aryna Kharytonenka 4 min 21 listopada 2019
Enscape™ Real-Time Rendering  - New for BricsCAD BIM V20
The integration of Enscape real-time architectural renderer into BricsCAD BIM V20 delivers world-class visualization capabilities. This integration lets BricsCAD BIM users create interactive, photo-realistic rendering of their BIM models in real-time. With a single click, you can launch Enscape, walk through your rendered project, and experience your designs as if they were already built.
Watch the 1 Minute Bricsys-Enscape Demo
Enscape™ Real-Time Rendering -HOK-Enscape
Image credit HOK
Use cases:
  • Client presentation
  • Design review
  • Internal presentation
  • Quick render creation
Highlights:
  • Effortless usage Rendering with one click
  • Live link to BricsCAD Changes made in BricsCAD are directly visible in Enscape
  • Standalone export Create an .exe file from your project that runs without BricsCAD
  • Video Path Multiple options for every keyframe
  • 360° Panorama Views
  • Real-time walk-through
With Enscape, high-quality real-time rendering is integrated into the BIM design workflow. It does not require special skills to use, and it leverages existing BIM data to provide a one-click user experience. The integration of Enscape will save architects, designers, and engineers time during design reviews and help them to create compelling client presentations, -- Tiemen Strobbe, BIM Product Owner at Bricsys.
What is the Enscape/BricsCAD BIM connector?
Enscape is a real-time rendering plugin for BricsCAD. With a single click, you can start Enscape in seconds and walk through your fully rendered model project. There is no need to export to other programs! Changes made in BricsCAD BIM are reflected immediately in Enscape, making it possible for clients to give detailed feedback on your designs in real-time.
Enscape™ Real-Time Rendering -Kitchen-1024x564
Render materials, lights and textures with Enscape and BricsCAD
Real-time Rendering
You can quickly explore different materials and design options to present to clients. In case your client wants to see something different in the design, you can edit the changes in BricsCAD, and Enscape will immediately show the changes you have made to the project.
With the option to create a standalone file of your project, you can send an Enscape file to your clients or colleagues, which allows for quick demonstrations. Enscape has become a standard application in projects worldwide, in international companies like AedasFoster + Partners and HOK.
When you are ready to present your projects to your clients, there's no need to upload them to the cloud or export them to other programs.
The partnership with Bricsys is a great opportunity to provide the benefits of Enscape to a broad audience in the AEC industry and beyond. Enscape fits perfectly in the visualization portfolio of BricsCAD and allows users to fasten up their design and decision-making processes substantially, -- Jonathan Knöfel, VP Customer Services at Enscape.
Enscape™ Real-Time Rendering -screenshot Swimming-Pool-1024x542
Render water, glass, light and landscape.
Minimum system requirements:
  • Windows 7 64 Bit or higher
  • Intel i5 CPU or higher
  • NVIDIA or AMD GPU with 2GB VRAM
    Supports OpenGL 4.3
    NVIDIA GeForce GTX 660/Quadro K2000 and newer
    AMD Radeon R9 260/FirePro W5100 and newer
  • 4 GB RAM (8 GB recommended)
  • 2 GB Video-RAM (4 GB recommended)
Buy Enscape directly from inside of BricsCAD, thanks to our new App Store.
Learn how to use Enscape in BricsCAD.
Enscape for BricsCAD will be discontinued and taken down from the Bricsys App Store on 22/10/2023. All active subscriptions purchased before this date will keep receiving support until the subscription expires. Bricsys will provide a version of “Enscape for BricsCAD” that will be compatible with BricsCAD v24.1 If you have any questions please click the “Contact” button in the App Store and create a Support Request.
What's New for BricsCAD BIM V20?
10 marca 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Śledź nas w mediach społecznościowych
