BIM Rysowanie 2D Modelowanie 3D
2D, 3D, BIM - 12: A Rubber Duck
Przez Rose Barfield 4 min 25 czerwca 2019
2D, 3D, BIM - 12 A Rubber Duck
Last time, I showed you how to create your own library of component parts. This time relax with a fun project to advance your modeling skills: a rubber duck. There are still many, many more ways of working in BricsCAD, but this should give you a good starting point.
You will need to download the linework .dwg file. You can make your own, but the purpose of this post it to get you using 3D tools, if you still need help with 2D drawing then be sure to check our free 2D tutorials.
New commands covered:
  1. DMDEFORMPOINT
Watch video on YouTube
The Body
I used the Loft command, as covered in the sink -- part 6 and the toilet -- part 7. I then added wings using the DeformPoint command. To finish I used spheres to create the head and eyes.
How to do this:
  1. To start, download the linework or, if you're feeling adventurous, make your own.2D, 3D, BIM - 12 A Rubber Duck- 1 lines-1024x576
  2. Loft between the curves to create a body.2D, 3D, BIM - 12 A Rubber Duck- 2loft
  3. Use DMDEFORMPOINT to extrude a wing.2D, 3D, BIM - 12 A Rubber Duck- 3 wing
  4. Repeat on the other side.
  5. Use a sphere to create the head.2D, 3D, BIM - 12 A Rubber Duck- 5 head-1024x568
  6. Use another sphere to create the eye.2D, 3D, BIM - 12 A Rubber Duck- 6 eye-1024x576Tip: Use DUCS and hit Shift to set the drawing plane.
  7. Repeat with a smaller sphere.2D, 3D, BIM - 12 A Rubber Duck- 7 eye2-1024x516
  8. Use subtract to remove the second sphere from the first.2D, 3D, BIM - 12 A Rubber Duck- 8 eye3
  9. Optional: Select the face of the pupil and, in the Properties panel, change the color. (All other colors are set by layer).
  10. Mirror on the other side.
You should now have something that looks like this:2D, 3D, BIM - 12 A Rubber Duck- 9 eye4-1024x813
The Beak
To make the rubber duck's beak I used similar techniques. However, this time I used the surface version of the Loft tool. In these images I have isolated the beak layer so it's easier to see what is happening.
How to do this:
  1. Loft the top bill of the beak. This time we are creating surfaces only.
    In the Structure panel these splines are found in the 'beak' layer.2D, 3D, BIM - 12 A Rubber Duck- beak1 upper bill
  2. Repeat on the lower bill.
    In the Structure panel these splines are found in the 'beak' layer.2D, 3D, BIM - 12 A Rubber Duck- beak2 lowerbill
  3. In the Structure panel select the splines these are found in the 'beak_guidelines' layer.2D, 3D, BIM - 12 A Rubber Duck- beak3 lines-1024x575
  4. Use DMTHICKEN to give the bill a ridge. This technique was covered in part 6 -- the sink.2D, 3D, BIM - 12 A Rubber Duck- beak4 dmthicken-1024x576 Extra information: When I created the linework for the beak I doubled the splines across the front of the bill. I used the BREAK command to make the lines I used for lofting in steps 1-2. For the ridge, I kept them joined.
Final results
You should now have a rubber duck that looks something like this:
2D, 3D, BIM - 12 A Rubber Duck- final multiview-1200x675
Next Time
Join me next time when I show you how to slice an object for laser cutting.
Don't have BricsCAD yet?
Easy to try, easy to buy, easy to own. That's BricsCAD. Try all of our products, for free for 30 days at www.bricsys.com. Freedom of choice, plus perpetual (permanent) product licenses that work with all languages, in all places. You'll love what we've built for you with BricsCAD.
Keep Reading
  1. Moving from 2D to 3D CAD
  2. 3D Drawing from engineering plans
  3. Drawing everything but the kitchen sink
  4. More Advanced Modeling
  5. The Shower
  6. The Sink
  7. The Toilet
  8. Walls and Floors
  9. The Roof
  10. Windows and Doors
  11. Create your own components
  12. Rubber Duck
  13. Laser-cut puzzle project
Note: This series is intended as a guide to demonstrate how to use different aspects of 3D modeling tools. It may not always demonstrate the fastest way of getting the result. Keep coming back to see if we cover a faster technique at a later date.
10 marca 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Śledź nas w mediach społecznościowych
