Document Managment
File management and the Transfer Tool in Bricsys 24/7
By Kelsey Grant 2 min 11. juni 2017
Simplify collaborative project file management with Bricsys 24/7
The Bricsys 24/7 collaborative cloud features an app that will assist you with project file management tasks. The Transfer Tool is a local desktop application that helps you transfer documents, folders or a complete folder structure between your local PC and the Bricsys 24/7 cloud. This split screen user interface let you upload or download files via drag-and-drop.
Using the Transfer Tool, you can also set up local file open and edit functionality. This lets you choose which file to open -- the local or the cloud copy --  when you double-click a file in 24/7.
The Bricsys 24/7 Transfer tool has four main features:
Move files between your local PC and the Bricsys 24/7 cloud
The transfer tool runs on your PC, and features a split screen user interface that lets you easily drag-and-drop files to move them to & from Bricsys 24/7.
Upload a folder structure to Bricsys 24/7
Don't want to manually recreate your local drive's folder structure in 24/7? The Transfer Tool takes care of this process for you. Just drag-and-drop an entire top-level folder (or sub-directories with additional folder structures) into the tool. It will automatically recreate the exact folder structure on the Bricsys 24/7 cloud servers.
View project files on your laptop or mobile device
The Transfer Tool lets you download and view your project files on your laptop or mobile device. Just drag-and-drop from the 24/7 side of the Transfer tool window to download a folder (or a complete folder structure) to your local machine. Bricsys 24/7 supports more than 70 document types, from text to image to office formats. Bricsys 24/7 also understands CAD files and reference file dependencies.
Open a document locally to make a fast revision
Need to make a quick change to a project document? The Transfer Tool lets you open a document stored in the Bricsys 24/7 cloud, directly on your device for fast editing. Save your changes, and the Transfer tool will upload your changes to the cloud and create a new file revision for tracking.
If you use Bricsys 24/7, you'll want the Transfer Tool today! To get Bricsys 24/7 Transfer tool, just download it here.
15. april 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
8. april 2024 4 min
In V24.2, we've further enhanced BricsCAD's DWG compatibility to ensure the rapid creation of design documentation by focusing on the 2D drawing creation workflow. To create the smoothest collaboration, we've ensured you can open and edit the drawings you create in BricsCAD in other DWG-based CAD programs. Let's dive into the enhancements we've made!
25. mars 2024 4 min
Follow us on social media
