3D Tips
Tuesday Tips - Everything you need to know about Render Materials in BricsCAD
As standard, BricsCAD comes with a large number of free materials and textures but even with all these materials at your fingertips, you might still want to add your own materials to the library. The good news is: you can create and import your own materials into BricsCAD!
Free materials and textures
Although you can create your own texture from scratch, it's often easier to simply download them. Here's a useful list of sites where you can download free materials and textures:
  • cc0textures -- 700+ free, public domain textures and growing.
-   Texture Heaven -- Huge selection of high-quality materials specifically building/natural textures.
-   Plain Textures -- Don't let the name fool you! this website has just about any texture; food, rusted signage, stormy skies...
-   PBR Materials -- You need to create an account, but there are 100s of free downloads
-   Poliigon -- Large variety of well-prepared textures at different resolutions including rendering maps.
-   Arrowway Textures -- Range of building material textures, all at high resolution.
-   Texture library -- Basic website, but has a good range of textures.
-   Free Stock Textures -- More Graphic design-focused, but useful for more creative projects.
-   3DXo -- Also has some free, 3D models for download!
There are also plenty of places where you can download free 2D and 3D models. Many of these sites offer free textures and render materials and often the models come with textures preloaded!
How to create your own custom materials in BricsCAD:
1.  Enter MATERIALS into the Command line or navigate to Materials in the Drawing Explorer.
2.  Set the values for the material.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- texture-1024x748
3.  Set the color or add a raster image and a texture map, if relevant; .bmp, .jpg, .jpeg, .png or gif.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- color-1024x748
4.  Give the material a name.
5.  Right-click the material name and select 'Add Material(s) to Library' from the dropdown menu.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- add to Ibrary-1024x746
The material will now be available to you in the 'User Defined' category of the Render Materials panel. Learn more about creating your own Render Materials in BricsCAD.
How to add a material to your model in BricsCAD:
The easiest way to add the newly created material to a model:
1.  Open the Render Materials Panel (New for V20).
2.  Click the materials and drag and drop the material onto your model.
   Hold Ctrl to assign the material to a complete object or simply drag and drop the material to each face in turn.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- wallpaper
If the material is local (only saved to this drawing), you can find the material under the 'In drawing' section of the Render Materials panel. If the Material is assigned to the Library you will find it under the 'User defined' section.
You can also use the Properties panel. Select an object and assign the material using the 'Materials' drop-down menu under the 3D Visualization section.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- drop down
How to assign a material to a layer:
1.  Use the Properties Panel. Make sure that the object(s) is assigned to the correct layer and that the 'Materials' drop-down menu under the 3D Visualization section is set to 'By Layer'.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- by layer
2.  Open the Layers panel.
3.  Under the 'Material' column, use the drop-down menu to assign a material to all the objects on a given layer.Tuesday Tips - Everything you need to know about Render Materials in BricsCAD- drop down layer
Where do you download free textures and materials?
Are there any great websites I've missed off the list above? Add your favorite website in the comments below!
Download BricsCAD free for 30-days
Get started with BricsCAD
Permanent or subscription licenses that work in all languages, in all regions.
Disclaimer: These links are being provided as a convenience and for informational purposes only; they do not constitute an endorsement or an approval by Bricsys of any of the products, services or opinions of the corporation or organization or individual. Bricsys bears no responsibility for the accuracy, legality or content of the external site or for that of subsequent links. Contact the external site for answers to questions regarding its content.
More Tuesday Tips:
-   BricsCAD Trial Versions
-   Glossary of CAD terms
-   Reduce your work time with The Quad
-   Save time with Propagate
-   Edit polylines in BricsCAD
-   Converting to .dwg
-   BIMTags
-   11 -- ways to draw a square in BricsCAD
-   A quick guide to DXF
-   Solids, Surfaces, and Meshes
-   Sweep
-   Callouts, leader lines & balloons
-   Automate Technical Drawing
-   Orthographic Drawing from a 3D Model in 20 Seconds
-   'api-ms-win-crt-runtime-dll' Error while starting BricsCAD
-   Transform 2D Entities with Stretch
-   Move, Edit and Change Entities at Hyper Speed with BricsCAD
-   The BricsCAD® Hotkey Assistant & Tips Panel
23 november 2022 5 min
How Technology Can Overcome the Top Challenges in Construction
New technology solutions continue to improve productivity and efficiency on construction sites around the world. However, upgraded design software can only push these improvements so far. To truly overcome the construction industry’s top challenges, the sectors’ professionals - architects, engineers, contractors and building owners - must embrace innovative solutions that provide the tools for stronger and better collaboration.
Lees verder
Volg ons op sociale media
blog-facebook-icon
blog-twitter-icon
blog-instagram-icon
blog-youtube-icon
blog-linkedin-icon
Dit is Bricsys
Bricsys, onderdeel van Hexagon, is het wereldwijde technologiebedrijf dat de BricsCAD® familie van computer aided design producten en het Bricsys 24/7 projectsamenwerkingsplatform creëert.
© 2022 Bricsys NV. All rights reserved.
Part of hexagon
