2D schetsen 3D Modelleren
Printing From Paper Space in BricsCAD
Door The Bricsys Team 3 min 29 september 2022
Printing 2D drawings and 3D models in BricsCAD 6.36-6.42
To print from Paper Space, you can click on the ‘Layout 1’ tab, which is the default layout.
Printing 2D drawings and 3D models in BricsCAD 3.46-3.50
If this is the first time you opened the default layout, you can hit the delete key to delete the default layout. Then right-click on the ‘Layout 1’ tab and click on ‘Page Setup’ to set up the page for printing. You can use most of the same settings here that we went over in the Model Space section, like paper size, orientation, and plot style. But since you will specify the scale inside the viewpoint, you will want to keep the 1:1 scale and have ‘Layout’ selected in ‘Plot area.’
Printing 2D drawings and 3D models in BricsCAD 4.21-4.28
You can save the settings when you are done and will be back in Paper Space. The dotted line around the drawing is the plot margin. Nothing outside of the dotted line will be printed.
Printing 2D drawings and 3D models in BricsCAD 4.59-5.02
Now you will want to create viewports in your layout. To do that, click on the ‘View’ tab and then click on ‘Paper Space Views.’
Printing 2D drawings and 3D models in BricsCAD 5.15-5.20
Then click and drag in the view to specify the viewport. When you are done, you will see the drawing from the Model Space in the viewport.
Printing 2D drawings and 3D models in BricsCAD 5.23-5.27
Then you can adjust the drawing in the viewport. First, double-click to activate it. Then you can use pan and zoom to focus on a specific part of your drawing.
Printing 2D drawings and 3D models in BricsCAD 5.40-5.43
You can control the scale of the viewport by clicking on the viewport border, clicking on the ‘Properties’ panel, and adjusting the scale in the ‘Standard scale’ menu.
Printing 2D drawings and 3D models in BricsCAD 5.53-6.02
You can add more than one viewport to the layout to show other parts of your drawing.
Once you have the scale of your viewports the way you want, you can lock the scale to prevent any changes by selecting your viewports and setting ‘Display locked’ to ‘Yes’ in the ‘Properties’ panel. You will now be able to zoom and pan the entire layout at once.
Printing 2D drawings and 3D models in BricsCAD 7.06-7.12
If you need to copy a layout, right-click on the layout’s tab, click ‘Copy’ and give the new layout a name.
Printing 2D drawings and 3D models in BricsCAD 7.33-7.41
When you copy a layout, it will have all the settings that the previous layout had. If you want to modify the viewports in this new drawing, you can select both viewports and set ‘Display locked’ back to ‘No’ in the ‘Properties’ panel. Then you can double-click inside a viewport, pan to display a different part of the drawing, and adjust the size of the viewport to fit.
Printing 2D drawings and 3D models in BricsCAD 8.31-8.36
Printing from the layout is like printing from Model Space. Just right-click on the layout’s tab and choose ‘Print.’
Watch the video tutorial on our Bricsys YouTube channel.
19 maart 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 maart 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Volg ons op sociale media
