2D schetsen
Move Guided - New for BricsCAD® V21
Door Rose Barfield 4 min 28 december 2020
On 27th October 2020, at the Bricsys® Digital Summit, Bricsys® launched BricsCAD® V21, available at different 5 license levels: BricsCAD® LiteBricsCAD® ProBricsCAD® MechanicalBricsCAD® BIM and BricsCAD® Ultimate. In this post, let's take a look at one of the new AI tools for BricsCAD® V21: Move Guided.
Building on the success of COPYGUIDED, Bricsys® has introduced  MOVEGUIDED. If you spend a lot of time editing drawings, moving details around and then fixing all the entities that are left behind, then MOVEGUIDED will save you hours of time.
Move Entities Intelligently
MOVEGUIDED makes it is easy to move elements on a 2D drawing.
If you already know COPYGUIDED , then you'll be pleased to hear that MOVEGUIDED works in exactly the same way, the only difference is that it moves the selected entities instead of copying them.
Move Guided - New for BricsCAD<sup>®</sup> V21- move guided
Use the move guided tool to intelligently move entities in a drawing.
MOVEGUIDED allows you to take any collection of entities in a 2D drawing and intelligently move them from one part of a drawing to another, similar location. This includes blocks, lines, arcs and hatches. At the new location, MOVEGUIDED intelligently snaps the selected entities to existing geometry, using "reference curves". If required, the tool automatically creates gaps when placing the entities. In the location the entities are moved from, MOVEGUIDED "heals" the drawing (e.g. fills in the gap or connects and joins lines).
For example: if you use MOVEGUIDED to move a door from one wall to another wall, BricsCAD® will automatically orientate and snap, the door to the new wall. At the same time, it will heal the wall at the location where the door used to be and create a doorway at the new location. Any lines or hatches will be healed. And no that doesn't mean a patchwork of hatches and lines will be left behind. BricsCAD will create continuous lines and hatches.
After you have selected the entity/entities that you wish to move, BricsCAD® will display a live preview, under your cursor. This allows you to see what the drawing will look like before you execute the command.
How to use Move Guided:
The command can be executed in "pre-pick mode" (first select the entities to copy, then launch the command, and finally, select any guide curves) or "post-pick mode" (select entities during command).
Move Guided - New for BricsCAD<sup>®</sup> V21- moveguided
  1. Enter MOVEGUIDED.
  2. If you have already selected the entity/entities to move:
    Select the curves to be used as a reference and hit Enter.
    OR
    Use a selection box to select the entity/entities to move.
    Move Guided - New for BricsCAD<sup>®</sup> V21- selection windowNote: All entities completely inside the selection window (yellow) will be moved. Entities not completely inside the selection window (blue) will be used as reference curves.
  3. Move your cursor. A preview will display. The reference curves snap to matching lines under the cursor.
    Note: Blue arrows indicate the anchor points of the reference curves.Move Guided - New for BricsCAD<sup>®</sup> V21- guide arrows
    TIP: Move the cursor to the other side of the reference curves to mirror the selection set.
            Hit the Ctrl key during step 3 to top copy the whole selection region, including empty spaces.
  4. Click to place the entities
    OR
    Type a distance in the dynamic entry fields. Hit TAB to switch between fields.
  5. Hit Enter to confirm.Move Guided - New for BricsCAD<sup>®</sup> V21- dyanmic-boxes
But that's not all that's new for BricsCAD® V21!
To see all new features for BricsCAD® V21, be sure to check the release notes and come back to the blog, as we will be exploring more features!
Try BricsCAD® Ultimate V21, free for 30-days without obligation.
Try BricsCAD Free
Discover more new BricsCAD® V21 Features:
19 maart 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 maart 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Volg ons op sociale media
