3D Modelleren
2D, 3D, BIM - 6: The Bathroom Part 2 - The Sink
Door Rose Barfield 5 min 11 april 2019
2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink
Last week I showed you how to make a shower cubicle in BricsCAD. In this tutorial, I will be showing you how I created a CAD sink. We will be reinforcing some of the commands you've already learned and adding a few more.
Commands covered this week
Watch video on YouTube
The Sink
I began by revolving a closed polyline to create the sink base and shelled. I then lofted to create the bowl and shelled again. To finish I extruded two holes for the faucet and the drain.
2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- sink-01-1024x817
2D plan views of the model
To do this:
  1. Start by drawing out your sink shape in polylines. Use the POLYLINE and ELLIPSE commands to create the shapes.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 1-768x455
  2. REVOLVE the base.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 2-1024x619
  3. SOLIDEDIT -- Body -- Shell. Select the top and bottom surfaces for removal. The distance is 0.5.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- hollow
  4. Use LOFT. Select the closed polylines to create the bowl shape. Select the lowest ellipse first and the topmost ellipse last.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- loft
  5. SOLIDEDIT -- Body -- Shell. Select the top surface of the bowl. The distance is 1.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 5-1024x571
  6. Extrude a circle through the center of the bowl to create a plug hole. Use the Subtract mode.
  7. Extrude the faucet hole. Use the Both sides mode.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 6-1024x626
The Faucet
Next created the faucet. I extruded 3 cylinders to specified dimensions, then extruded 2 more at 90°. Finally, I shaved off the excess material and added an exit for the water.
2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- tap-01-1024x724
To do this:
  1. Create a new layer. Use this as the drawing layer.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- layers
  2. Extrude the circles to the correct height.
    Or, use the CYLINDER command.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 9-1024x691
  3. At 90 degrees extrude two cylinders to create the handle and the spout.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 10-1024x716
  4. Use Extrude-Both sides -- Subtract to remove an angled section from the spout.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 11-1024x688
  5. On the surface, you just created, draw a circle in the center of the surface. Use ESnaps -- Geometric center.
    Or, use a cylinder.
    Note: Hit Shift to lock the drawing surface to the face.
  6. OFFSET the edge of the cylinder. The distance is 0.1.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 12-1024x680
  7. Extrude into the hole.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 13-1024x692
  8. Optional: Use SOLIDEDIT -- Body -- Shell to hollow out the faucet.
2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 14-1024x692
Putting it together
The final step was to put the faucet in place and add the piping.
To do this:
  1. Stay on the same layer. MOVE the faucet into position on the hole of the bowl.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 15-1024x607
  2. Using DUCS draw a rectangle along the z-axis, from the base of the faucet.
  3. Use TRIM to cut remove two of the lines. You should now have two polylines joined at a 90° angle.
    Or, draw 2 polylines at 90°.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 16-1024x553
  4. Fillet the polyline. The radius is 10.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 17-1024x552
  5. SWEEP the vertex of the base of the faucet along the line.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 18-1024x599
  6. Repeat steps 2-5, using the drainage hole as the sweep profile.2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 19-1024x566
  7. Use the Subtract command to create a hole in the base. Select the base, then select the drainage piping.
  8. As a final touch, you can use the SHELL command to hollow out the piping.
2D, 3D, BIM - 6 The Bathroom Part 2 - The Sink- 20-1024x676
Next Time
Join me next time when I show you how to create a toilet with BricsCAD
Don't have BricsCAD yet?
Easy to try, easy to buy, easy to own. That's BricsCAD. Try all of our products, for free for 30 days at www.bricsys.com. Freedom of choice, plus perpetual (permanent) product licenses that work with all languages, in all places. You'll love what we've built for you with BricsCAD.
Keep Reading
  1. Moving from 2D to 3D CAD
  2. 3D Drawing from engineering plans
  3. Drawing everything but the kitchen sink
  4. More Advanced Modeling
  5. The Shower
  6. The Sink
  7. The Toilet
  8. Walls and Floors
  9. The Roof
  10. Windows and Doors
  11. Create your own components
  12. Rubber Duck
  13. Laser-cut puzzle project
Note: This series is intended as a guide to demonstrate how to use different aspects of 3D modeling tools. It may not always demonstrate the fastest way of getting the result. Keep coming back to see if we cover a faster technique at a later date.
19 maart 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 maart 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Volg ons op sociale media
