2D schetsen 3D Modelleren BIM
2D, 3D, BIM - 13: Laser-cut puzzle project
Door Rose Barfield 5 min 29 augustus 2019
2D, 3D, BIM - 13 Laser-cut puzzle project
Last time, I showed you how to create your own library of component parts. This time, follow along with a, laser-cut puzzle project. Learn how to convert solid entities into laser-cut ready objects.
Although some free tools exist that automatically split a 3D model into a laser-cut puzzle, they are not yet capable of extremely complex objects with many different angles. The model used in this project is an oversimplified example, however, the principles can be applied to far more complicated objects. The only limitation is your imagination!
Commands covered:
Watch video on YouTube
We're going to start off with a 3D model, if you don't have any you can download free CAD objects. For this project, you're going to want to start with a single solid. The simpler the shape the easier it will be to split up.
Converting a solid into a laser-cut puzzle
I began by splitting my object into slices, the extracting the faces and using DMThicken to convert the faces into solids. I repeated this action on a "cutting" layer and used these objects to generate the slots.
How to do this:
  1. COPY the entity as shown.2D, 3D, BIM - 13 Laser-cut puzzle project- 1 copy-1024x503
  2. Use the SLICE tool to split the solid as shown.2D, 3D, BIM - 13 Laser-cut puzzle project- 2 slice-1024x651
  3. Use XFACES to extract the face of each cutting plane.2D, 3D, BIM - 13 Laser-cut puzzle project- 3 faces-1024x608
  4. Delete the excess solids.
    Tip: Use the entities panel to select and remove the solids.
  5. COPY everything onto a new "cutting" layer.2D, 3D, BIM - 13 Laser-cut puzzle project- 5-5 copy-1024x510
  6. DMTHICKEN the first set of regions. Distance: 2.5, both sides.2D, 3D, BIM - 13 Laser-cut puzzle project- 5 DM thicken-1024x559
  7. Repeat on the cutting layer. This time with a distance of 2.6. This is to allow for tolerance on the slots.
  8. Delete all regions.
  9. EXTRUDE a surface from the centerline, through the cutting layer entities, as shown.2D, 3D, BIM - 13 Laser-cut puzzle project- 6 extrude surface-1024x487
  10. Use this as a slicing object with the SLICE command.
  11. Repeat on all entities on the "cutting" layer.
    You should now have something that looks like this:2D, 3D, BIM - 13 Laser-cut puzzle project- 7 mirror-1024x577
  12. Seperate the sections, as shown.2D, 3D, BIM - 13 Laser-cut puzzle project- 8 copy-1024x498
  13. Move the cutting objects into position.
    2D, 3D, BIM - 13 Laser-cut puzzle project- 9 move-1024x495Tip: Use the centerline snaping points to move everything into position. For best results, you will need to slightly offset the height that the cutting object meets the object to be cut out.
  14. Subtract the cutting layer from the main layer.
    The results should look like this:2D, 3D, BIM - 13 Laser-cut puzzle project- 11 results-1024x579Note: Some of these slots are angled. Because laser cutters cut at 90 degrees, you will need to make some manual adjustments.
  15. To finish your laser cut puzzle project, simply slot everything together.2D, 3D, BIM - 13 Laser-cut puzzle project- 10 slottogether-1024x637
Create the 2D file
A laser-cut -ready .dxf file can be created by simply arranging all the pieces and then hitting EXPORT.
Tip: Use VIEWBASE to create a top-down view automatically, no need to worry about making sure that all the objects are on the same plane!
Automatically generating laser-cut-ready files
I tested this model on an automatic, laser-cut puzzle, generation software. Even when I spent a large amount of time adjusting the results, the software was unable to successfully generate a set of plans equivalent to that of above.
2D, 3D, BIM - 13 Laser-cut puzzle project- automatic lasercut-1024x624
Model automatically generated using free software, due to the large number of angles at which the legs meet the body. Note the red pieces are not manufacturable.
Don't have BricsCAD yet?
Easy to try, easy to buy, easy to own. That's BricsCAD. Try all of our products, for free for 30 days at www.bricsys.com. Freedom of choice, plus perpetual (permanent) product licenses that work with all languages, in all places. You'll love what we've built for you with BricsCAD.
Keep Reading
  1. Moving from 2D to 3D CAD
  2. 3D Drawing from engineering plans
  3. Drawing everything but the kitchen sink
  4. More Advanced Modeling
  5. The Shower
  6. The Sink
  7. The Toilet
  8. Walls and Floors
  9. The Roof
  10. Windows and Doors
  11. Create your own components
  12. Rubber Duck
Note: This series is intended as a guide to demonstrate how to use different aspects of 3D modeling tools. It may not always demonstrate the fastest way of getting the result. Keep coming back to see if we cover a faster technique at a later date.
19 maart 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 maart 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Volg ons op sociale media
