Applicaties
Unfolded Sheet Metal with LITIO
Door Juan Mario 2 min 3 oktober 2019
LITIO is a ducting sheet metal add-on for BricsCAD that calculates and draws the flat (unfolded) sheet metal developments for the sheet metal-processing industry. It's the ideal software for the construction of HVAC, hoppers, cyclones, dust extraction, ducts, conveying systems, silos, piping, and many more.
With LITIO you can draw your sheet metal developments directly in BricsCAD Pro (V11 and higher) without the need for BricsCAD Mechanical.
Key features:
  • More than 30 different patterns
  • Developments calculated according to German standard DIN 6935
  • Input in, out or middle (neutral fiber) dimensions
  • Draws a 2D and 3D representation (contour and mesh)
  • Works with BricsCAD v.11 and higher (Classic, Pro, and Platinum)
LITIO calculates flat (unfolded) sheet metal developments of:
  • Ducts
  • Rectangle to round transitions
  • Cylinders
  • Cones
  • Pipe intersections
  • Connections
  • Ys
  • Elbows
  • And more!
How to use LITIO
  1. Select the 3D surface you want to unfold.
    Unfolded Sheet Metal with LITIO- 1-pattern-selection
    Pattern selection
  2. Optional Enter the settings dialog, to change your LITIO configurations:
    • Inside, outside or mid-cross-sectional dimensions and/or height specifications.
    • Choose to draw the 3D surface and the unfolded sheet as:
      • A mesh optimized for bending.
      • A 2D contour optimized for cutting.
    • The precision.
      Unfolded Sheet Metal with LITIO- 7-settings-dialog
      Settings dialog
    Note: The program automatically sets the units according to the units used in the current drawing session.
  3. Input your pattern parameters.
    Unfolded Sheet Metal with LITIO- 2-pattern-cone-duct
    Pattern -- Intersection -- Cone with Rectangular Duct
    Unfolded Sheet Metal with LITIO- 3-pattern-rectangle2round
    Rectangle to Round
    Unfolded Sheet Metal with LITIO- 5-pattern-bifurcation
    Pattern Bifurcation
    Unfolded Sheet Metal with LITIO- 6-pattern-bend
    Pattern Bend
  4. Using your input parameters, LITIO draws a 2D and 3D representation of your design.
    Unfolded Sheet Metal with LITIO- 0-pattern-and-development-e1568812547414-1024x545
    Pattern and Development
  5. Use the 2D developments for NC CAM cutting (plasma, laser, etc.) or manual cutting (scaled 1:1 paper templates).
Discover more 3rd party BricsCAD apps
There are hundreds of 3rd party apps available at the BricsCAD Application Store. Easy to try, easy to buy, easy to own. That's BricsCAD®. Try it, free for 30 days at www.bricsys.com. Freedom of choice, plus perpetual (permanent) product licenses that work with all languages, in all places. You'll love what we've built for you with the BricsCAD® product family.
19 maart 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 maart 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Volg ons op sociale media
