2D schetsen
Tuesday Tips - Transform 2D Entities with Stretch
Door Rose Barfield 2 min 5 april 2021
If you're looking to transform and scale 2D entities non-uniformly, then you need STRETCH.
Use it to change the size and shape of 2D entities, with just a few clicks of the mouse.
Transform 2D Entities with Stretch- stretch 2
This is a 2D, isometric drawing, not a 3D model.
To stretch entities
  1. Enter the STRETCH command.
  2. Select a portion of the 2D entities to move.
  3. Select a base point and an endpoint.
    The selection should now be stretched.
    Note: To add or remove entities from the selection, you can use any selection method you would normally use.
Warning: This command only works in 2D.
Get a Grip
STRETCH isn't the only way to change the shape of a 2D entity; you can also manipulate entities using grips.Transform 2D Entities with Stretch- grips
How to modify a drawing with grips:
  1. Click the entity you want to modify. The entity grips display.
  2. Click a grip to activate it. The grip will change color.
    Tip You can change the color of grips in the settings dialog.
  3. Hold Shift to select multiple grips.
  4. Release Shift and move the selected grips.
    Tip This also works in 3D.
Download BricsCAD free for 30-days
Transform 2D entities with BricsCAD®
Permanent or subscription licenses that work in all languages and regions.
More Tuesday Tips:
15 april 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
25 maart 2024 4 min
Volg ons op sociale media
