Applicaties
Steel Detailing Software from Parabuild
Door Rose Barfield 1 min 26 februari 2020
Bricsys Site Map
Watch video on YouTube
Parabuild is a steel detailing software to help you build 3D models of all types of structural steel, with the required BIM data. It allows you to automatically produce the drawings and files needed to fabricate and erect a structure, directly from the model.
It has an intuitive user interface which makes it easy to use and easy to learn. All connections are defined in constraint-driven, parametric drawings. This allows you to modify existing connections and create your own.
Once the model is complete, fully dimensioned workshop drawings and BOMs (Bills of Materials) can be created automatically.
Create CNC output at the click of a button, with many options to suit the machines you have, including advanced time-saving scribing options.
You can download it on the BricsCAD® App Store.
Start Using BricsCAD Today
Permanent or subscription licenses that work in all languages, in all regions.
Free BricsCAD 30-day trial
19 maart 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 maart 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Volg ons op sociale media
