2D braižymas
The View Base Command - Paper Space in BricsCAD
Autorius Rose Barfield 3 min. 2021 m. gegužės 13 d.
In BricsCAD there are two main workspaces: Paper Space and Model Space. In this series we're going to explore the Paper Space workspace, what it does, how it works, why it's used and the various features, such as viewports, templates and annotations.
In the last post we looked at how to add annotations to layouts in Paper Space. In this post we will look at the VIEWBASE command.
What is the VIEWBASE command?
VIEWBASE  automatically generates associative, isometric and orthographic "flat" views. These are known as "drawing views". These can then be used to create section and detail views using the VIEWSECTION command.
There are many advantages to using the VIEWBASE command over viewports, including speed, accuracy, control and automatic generation of section and detail views.
How to use the VIEWBASE command
Launch the VIEWBASE command from Model Space and follow the instructions on the Command Line. If you get stuck there are detailed instructions on how to create drawing views the Bricsys Help Center.The View Base Command- view base command in action
Tip: Once you have placed the first view on the page, move the mouse around to generate additional projection views.
Hit Ctrl whilst creating views to move the projected view freely around the page. Click the mouse to place the view and hit Ctrl again to exit this view and generate more.
Tip: It's a good idea to switch on GENERATEASSOCVIEWS before you create views.
How to Change the Visual Style
You can turn hidden lines on and off, or change the Visual style as required. Do this with the Properties panel or use the VIEWEDIT command.
Note: To be able to change the visual style of views created with the VIEWBASE command, you must first change the geometry to "3D" or "Draft". You will not be able to change the visual style if the Geometry style is set to "2D". You can change the geometry when you create the drawing view or after with the Properties panel.
The View Base Command- view style
Properties for drawing views.
Editing drawing views
One advantage of the VIEWBASE command is that it makes it really easy to automatically generate section and detail views. The drawing views generated with the VIEWBASE and VIEWSECTION commands have their own, set of commands, that don't work on regular viewports.
The View Base Command- view base various-800x506
A selection of view, automatically generated with the VIEWBASE command and it's companion commands. Including detail views, 2D and 3D drawing styles and section views.
VIEWSECTION Create a cross-section view from a drawing view.
VIEWSECTIONSTYLE Modify the appearance section views.
VIEWPROJ Generate additional projected views from an existing drawing view.
VIEWDETAIL Create a larger, detail view from a portion of a drawing view.
VIEWDETAILSTYLE Modify the appearance of detail views.
VIEWUPDATE Update drawing views.
VIEWEXPORT Export the content of drawing views to the Model Space.
VIEWEDIT Change the scale and hidden line visibility of drawing views.
VIEWBREAK Create a broken view on drawing views.
How to hide the viewport frame
To turn off the viewport frame visibility, simply freeze the Drafting Viewports layer. However, it's worth noting that the frame is not actually visible when printed.
Hungry for more?
For more tips on how to generate drawing views automatically →
Learn more about Paper Space in BricsCAD:
2024 m. kovo 19 d. 8 min.
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
2024 m. kovo 10 d. 6 min.
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Sekite mus socialiniuose tinkluose
