2D braižymas 3D modeliavimas
Discover the Difference: More Efficient CAD command with Blockify & Parametric Blocks
Autorius Gavin England 3 min. 2022 m. spalio 5 d.
1_Blockify_Create_Block
In ‘BricsCAD: Discover the Difference’ today, we continue to look at the smart commands for users to enjoy more productivity. We explore how parametric blocks automates repetitive tasks and why creating either 2D or 3D block definitions in BricsCAD working with parametric constraints is intuitive and easy to use.
2_Blockify_Replace_Entities_with_Block
Blockify – parametric blocks for 2D and 3D drawings
When dealing with CAD drawings containing large numbers of common objects, blocks are a great way to make them more manageable. Normally, blocks must be individually defined, and common sets of entities manually replaced with the blocks you created. This can be frustrating and time consuming.
Blockify allows a block to be created from a set of 2D or 3D entities, and then it looks for similar sets of entities within the drawing (or a defined area) and automatically converts those to the same block.
Using the block command to define common objects has many benefits for users’ workflows. It reduces a drawing’s complexity, makes a drawing more manageable, and allows users to edit drawings quickly and easily.
3_Blocks_Parametric
Parametric blocks for the same entities
To make a block of entities, users can elect a set of entities using the Blockify command. Once the entity is created in a block, Blockify moves to the second step and automatically searches your chosen area or entire drawing for similar entities. It then applies the same block constraints to these entities.
Once Blockify has searched and replaced, you’ll notice that the drawing has far fewer entities, making it less complex and more manageable. And a process which was once time consuming and error-prone can now be completed in seconds.
4_Blocks_Guided_Insert
Parameterised geometry from 2D or 3D blocks
Once you have your blocks, users now have entities with the same parametric geometry in both 2D and 3D. This delivers entities with re-usable geometry which can be used many times in the drawing, in multiple sizes and orientations. As you work on the parameters, you can animate them to make sure they perform as expected, and use guided insert so the entity blocks adapt to the entities around them.
5_Blockify_Benefits
With Blockify and Parametric Blocks, you have the command tools to spend less time repetitive re-creating entities and re-use blocks in multiple different scenarios, quickly and easily.
Blockify and Parametric Blocks offer BricsCAD users productive tools through intelligent commands. We’ll be back next time with more ideas to free your time for design creativity - why not find out the BricsCAD difference for yourself? Download you free trial today.
Visit our migration page for more information on how easy it is to move to BricsCAD
2024 m. kovo 19 d. 8 min.
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
2024 m. kovo 10 d. 6 min.
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Sekite mus socialiniuose tinkluose
