Modelado 3D
Split Views with Viewports - Tuesday Tips
Por Rose Barfield 4 min 20 de julio de 2020
You might be surprised to learn that, in BricsCAD®, you can split the Model Space drawing view into two or more viewports. This allows you to see the same drawing in several different ways, for example, zoomed-in, from a different angle, with a different View style and even, with different visible layers.
How to split the view in your workspace
The create a split view in BricsCAD:
  1. Use the VPORTS  command or locate the Viewports button under the View tab of the Ribbon.
  2. Choose Create 2 viewports, Create 3 viewports or Create 4 viewports.
  3. Choose Horizontal, Vertical, Above, Below, Left or Right.
    Note: options vary based on the number of viewports selected in step 2.
The active viewport is surrounded by a heavy line. To change the active viewport, simply click the viewport you wish to make the active viewport or use the Ctrl+R shortcut to cycle between viewports.
Split Views with Viewports - Tuesday Tips- multi view
Change the view angle
Each viewport can have a different view angle. Control your view angles as you would a single viewport. Use the mouse or the LookFrom widget to change the view in the current viewport.
Want to split the workspace into more than 4 viewports?
No problem! You can split a viewport into yet more viewports.
  1. Select the viewport to split.
  2. Use the VPORTS  command.
  3. Select Create 2 viewports, Create 3 viewports or Create 4 viewports.
Split Views with Viewports - Tuesday Tips- join split
You can also merge viewports.
  1. Enter the VPORTS  command.
  2. Enter Join(J).
  3. Click to select the viewport you want to merge with the active viewport.
Change the visual style
You can change each viewport to a different visual style. You can even set different options in each viewport; Grid view, Layer view, etc.
Split Views with Viewports - Tuesday Tips- view style
Switch between viewport mid-command
You can move from one viewport to another mid-command. Simply click the other viewport (to set it as the active viewport) then continue the command. You can switch as many times as you need to.Split Views with Viewports - Tuesday Tips- switch
Save a viewport layout
To save a viewport:
  2. Enter Save(S).
  3. Choose a name for your viewport.
To load a saved viewport:
  2. Enter Restore(R).
  3. Type the name of the viewport to restore to.
Note: the viewport layout is only saved for the current drawing.
Revert to a single viewport
If you've had enough of split views you can quickly revert to a single view:
  2. Enter Single(SI) -- and you're back to one, single view of your model.Split Views with Viewports - Tuesday Tips- single
Alternatively, choose the Toggle option to temporarily, make the active viewport the only view.
More Tuesday Tips:
19 de marzo de 2024 9 min
Novedades de BricsCAD® V24.2
BricsCAD® V24.2 está repleto de funciones nuevas y mejoradas para el dibujo 2D, el modelado 3D, los flujos de trabajo civiles, topográficos, BIM y mecánicos. Con esta versión, el equipo de Bricsys incluyó varias funciones y mejoras nuevas para ayudarlo a acelerar el tiempo de entrega y brindarle una experiencia CAD familiar. Entonces, ¡profundicemos y exploremos las novedades de BricsCAD V24.2!
10 de marzo de 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Síganos en las redes sociales
