Modelado 3D
How to Model a 3D Chick - Easy Builds
Por Rose Barfield 5 min 1 de abril de 2021
How to Model a 3D Chick – Easy Builds
In this series, you will learn how to work with CAD, by following easy projects. Use only simple commands to build almost anything! For this tutorial, learn how to model a 3D chick.
Watch the video on YouTube
How to Model a 3D Chick in BricsCAD
Time to complete: 45 mins
Difficulty: 7/10
Commands used:
COPY
DMDEFORMPOINT
DMTHICKEN
DMSTITCH
EXTRUDE
FILLET
LCONNECT
LINE
LOFT
MANIPULATE
MIRROR
REGION
SPHERE
SPLINE
Tutorial: Model a 3D Chick in BricsCAD
  1. In the Properties panel, change the Visual style to Conceptual.How to Model a 3D Chick – Easy Builds- 1 cocept
  2. Draw a horizontal LINE, this will be useful as a center point later.How to Model a 3D Chick – Easy Builds- 1 line
  3. Draw a SPLINE with a slight curve to it (see image). Use the first line as a starting point. How to Model a 3D Chick – Easy Builds- 2 spline
  4. Use DMTHICKEN to convert the spline into a 3D solid. It should look like a bent cylinder and will become the body of the chick. How to Model a 3D Chick – Easy Builds- dmthicken
  5. FILLET the edges. How to Model a 3D Chick – Easy Builds- 5 fillet
  6. In the Properties panel, change the layer color to yellow.How to Model a 3D Chick – Easy Builds- 6 colour
  7. Draw a SPHERE towards the top of the body. This will become the head. How to Model a 3D Chick – Easy Builds- 7 sphere
  8. Use a SPLINE to draw a wing shape. Make sure that the spline is closed. How to Model a 3D Chick – Easy Builds- 8 spline
  9. Use REGION to convert the spline into a region. How to Model a 3D Chick – Easy Builds- 9 region
  10. COPY  the region. Keep it in exactly the same location.
  11. Use DMDEFORMPOINT to deform the top region into a curved, wing shape. How to Model a 3D Chick – Easy Builds- 11 deform
  12. Use DMSTITCH to convert the 2 regions into 1 solid.
    Tip: If you can not complete steps 9 -- 12 you can simply EXTRUDE  the spline and then FILLET the edges.
  13. Use the Manipulator to move the wing into position and rescale it, if required. How to Model a 3D Chick – Easy Builds- 13 manipulator
  14. Use LINE to draw a three-pointed chicken foot shape. How to Model a 3D Chick – Easy Builds- 14 foot
  15. Use LINE to draw a vertical "leg". How to Model a 3D Chick – Easy Builds- 15 leg
  16. Use DMTHICKEN to convert the lines into solids. How to Model a 3D Chick – Easy Builds- 16 thicken
  17. EXTRUDE the end of each toe at an angle.
    Tip: Use Tab to switch between the length and angle dynamic input boxes. How to Model a 3D Chick – Easy Builds- 17 extrude
  18. Use LCONNECT to connect the toes at the back of the foot. How to Model a 3D Chick – Easy Builds- 18 lconnect
  19. Use the Manipulator to move the leg into position, relative to the foot. How to Model a 3D Chick – Easy Builds- 20 manipulate
  20. FILLET the edge of the leg. How to Model a 3D Chick – Easy Builds- 20 fillet
  21. Use the Manipulator to move the leg into position and rescale it, if required. How to Model a 3D Chick – Easy Builds- 19 manipulator
  22. MIRROR the leg and the wing. How to Model a 3D Chick – Easy Builds- 22 mirror
  23. Reposition the legs, as required. How to Model a 3D Chick – Easy Builds- 21 manipulator
  24. Use SPLINE to draw the top and side profile of a beak.
    How to Model a 3D Chick – Easy Builds- wireframe break-800x591
If you like, you can download this image, import it into BricsCAD and trace it. Note: all lines are broken at meeting points.
__Tip:__ If you find this too complicated, make a cylinder and taper it to a point.
  1. LOFT between the splines to create a beak. How to Model a 3D Chick – Easy Builds- loft
  2. Use XEDGES  to extract the edges of the surfaces at the back of the beak.
    Tip: Use Tab on hover to toggle the selected entity.
    How to Model a 3D Chick – Easy Builds- 26 edges
Edges show in blue.
  1. LOFT between the splines to create two surfaces that cover the back of the beak. How to Model a 3D Chick – Easy Builds- surface
  2. Use DMSTITCH to convert the 6 regions into 2 solids.
  3. Use the Manipulator to move the beak into position and scale as required. How to Model a 3D Chick – Easy Builds- 28-manipulator
  4. Use SPHERE to draw an eye on the head. How to Model a 3D Chick – Easy Builds- 30 eye
  5. MIRROR the eye. How to Model a 3D Chick – Easy Builds- 30 mirror
  6. Use the Structure Browser to hide any unwanted entities in the drawing. How to Model a 3D Chick – Easy Builds- 31 stucture
  7. Use the Properties panel to change the color of the chick.How to Model a 3D Chick – Easy Builds- 32 colour
If you have completed all the above steps correctly, you should now have something like this:
How to Model a 3D Chick – Easy Builds- moneyshot
Happy CADing!
Download BricsCAD free for 30-days
Get started modeling a 3D chick in BricsCAD
Permanent or subscription licenses that work in all languages, in all regions.
Enjoy this project?
Why not try some other easy builds?
19 de marzo de 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 de marzo de 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Síganos en las redes sociales
