Noticias de productos
Floating Command Line - New for BricsCAD V20
Por Rose Barfield 2 min 2 de abril de 2020
BricsCAD V20 has had a facelift. Even the Command Line has a new look! In BricsCAD V20 the new-look command line is transparent and floats over your drawing.
How to unlock the new-look, floating Command Line:
  1. Make sure that the new floating frame is switched on.
    Starting with BricsCAD V20.2 the floating Command Line is switched on by default. If yours is not simply head over to the Settings dialog: Settings > Program options > Command line > Command line use new floating frame.
    Tick the box.Floating Command Line -Annotation-2020-03-24-080307-e1585044690746-585x495
  2. The next step is to make the Command line float. This is the same as making any other panel float. Left-click the ... and drag the mouse to reposition the Command Line.
    It's that simple!
    Floating Command Line -float
    How to make the command line float in BricsCAD V20.
How to revert back to the old skool Command Line
So you're not a fan of the new-look command line? No problem!
  1. Head over to the Settings dialog: Settings > Program options > Command line > Command line use new floating frame.
    Untick the box.Floating Command Line -switch-off-e1585044671374-585x496
  2. Dock the Command line. This is the same as docking any other panel. Left-click the top bar and drag the mouse to reposition the Command Line.
    Floating Command Line -dock
    How to dock the command line in BricsCAD.
    Ah back to "normal".
Dual Screen?
Did you know, you can even move the command line to another screen! Now you have even more room for drawing!
Floating Command Line -dual Screen-1024x288
Left: Floating command line. Right: BricsCAD Workspace.
But wait there's more!
Command options are now clickable, so you're no longer a slave to the keyboard!
Floating Command Line -click
What do you think of the new-look Command Line?
Let me know in the comments below.
Get the new BricsCAD
Permanent or subscription licenses that work in all languages, in all regions.
Free BricsCAD 30-day trial
More New Features for V20:
15 de abril de 2024 3 min
BricsCAD® Pro V24.2 - Performance Improvements
BricsCAD V24.2 is here, bringing with it a suite of performance improvements that promise to boost efficiency and stability. Tailored for drafters, designers, and fabricators across all industries, the latest version focuses on accelerating the creation of detailed design documentation essential for building, fabricating, and manufacturing processes. Let's take a closer look at the enhancements in V24.2 that will accelerate your time to deliverable.
8 de abril de 2024 4 min
In V24.2, we've further enhanced BricsCAD's DWG compatibility to ensure the rapid creation of design documentation by focusing on the 2D drawing creation workflow. To create the smoothest collaboration, we've ensured you can open and edit the drawings you create in BricsCAD in other DWG-based CAD programs. Let's dive into the enhancements we've made!
25 de marzo de 2024 4 min
Síganos en las redes sociales
