Modelado 3D
7 Must-Have Free CAD Programs and Online Tools
Por Rose Barfield 3 min 9 de enero de 2020
7-Must-Have-Free-CAD-Programs-and-Online-Tools
Here's my list of top 7 free CAD programs and online tools every CAD user should know:
  1. Voronator
  2. MeshConvert.com
  3. BricsCAD Shape
  4. ODA File Converter
  5. Slicer Fusion 360
  6. MeshLab
  7. Free LISP Commands
7 Must-Have Free CAD Programs and Online Tools- voronator 2-1024x520
1 Voronator
Voronator is a free online tool that converts any object into a Voronoi solid. You know, those cool, honeycomb-like structures. Just upload your model, wait a minute and download the 'voronoirized' solid. Export your BricsCAD file to .stl to use this tool. The file produced will be .ply, which brings me to number 2:
7 Must-Have Free CAD Programs and Online Tools- meshconvert-1024x515
2 MeshConvert.com
MeshConvert.com is a handy, free, online tool to converts meshes to .stl, collada, .obj or .ply formats.
7 Must-Have Free CAD Programs and Online Tools- userinterface-1024x575
3 BricsCAD Shape
If you don't already have it, download BricsCAD Shape, it's free for life and fully .dwg compatible. It imports and exports to a large number of formats and is super user-friendly. Start learning BricsCAD Shape.
7 Must-Have Free CAD Programs and Online Tools- oda
4 ODA File Converter
The Open Design Alliance has a free tool to convert .dwg file versions. This tool is based on the same core technology that's inside of BricsCAD. It can also convert .dwg to .dxf, a common format for driving simple machine tools.
7 Must-Have Free CAD Programs and Online Tools- slicer
5 Slicer Fusion 360
Autodesk® Slicer Fusion 360 is free and can be used as a standalone application. It automatically slices 3D models ready for laser cutting or CNC machining. It will also convert 3D solids to low poly, origami-style objects and will even show you animated assembly instructions.
7 Must-Have Free CAD Programs and Online Tools- meshLabs-1024x576
6 MeshLab
MeshLab is an open-source program specifically designed for editing, cleaning, healing, inspecting, rendering, texturing and converting 3D meshes. It also comes with some handy tools to convert point clouds to meshes. Export your BricsCAD models to .stl to be able to import them into MeshLab.
7 Must-Have Free CAD Programs and Online Tools- lee mac programing-1024x519
7 Free LISP Commands
Last on our list of free CAD programs and tools is Lee Mac Programing. Enjoy the convenience of LISP, but don't enjoy writing your own code? Then you're in luck! Head over to Lee Mac Programing, where they have 100s of free LISP codes, ready to download and use in BricsCAD!
Did I miss anything?
What are your favorite free CAD programs and tools? Let me know in the comments below.
19 de marzo de 2024 9 min
Novedades de BricsCAD® V24.2
BricsCAD® V24.2 está repleto de funciones nuevas y mejoradas para el dibujo 2D, el modelado 3D, los flujos de trabajo civiles, topográficos, BIM y mecánicos. Con esta versión, el equipo de Bricsys incluyó varias funciones y mejoras nuevas para ayudarlo a acelerar el tiempo de entrega y brindarle una experiencia CAD familiar. Entonces, ¡profundicemos y exploremos las novedades de BricsCAD V24.2!
10 de marzo de 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Síganos en las redes sociales
