Modelado 3D
BricsCAD Shape Interface - Joachim's Journey - Part 4
Por Joachim Corijn 3 min 18 de septiembre de 2019
During this stop on our BricsCAD Shape journey, we'll explore the user interface.
The BricsCAD Shape User Interface
BricsCAD Shape Interface - Joachim-s Journey -userinterface-1024x575
If you've never used CAD before you might be a little overwhelmed. Allow me to walk you through the main areas to help you get started quickly.
Menu bar
BricsCAD Shape Interface - Joachim-s Journey -menu-e1565617526622-1024x219
Like most programs, BricsCAD Shape displays a menu bar across the top of the screen. Here you'll find all of the commands for drafting and modeling. You'll also find the options to import, save and open files.
The Toolbar
BricsCAD Shape Interface - Joachim-s Journey -ribbon-e1565617567733-1024x215
At the top of your workspace, you'll find the Toolbar. This gives you handy access to some of the most frequently used commands. I'll cover some of these in more detail in a later post.
Command Line
BricsCAD Shape Interface - Joachim-s Journey -commandline-e1565617590758-1024x137
If you're new to CAD, you might overlook this very important area but don't! You'll quickly learn to love it. You'll find the commandline in the bottom, left-hand corner.
If one of the commands isn't working the way you expect, your first action should be to check here. It will tell you what to do next. You can also input instruction directly to it. Try typing box and see what happens!
For CAD veterans who rely heavily on the commandline there's good news: you can turn on a more 'classic' view by typing commandline, double-clicking it or hitting Shift+F2. Open the prompt history in a separate window by hitting F2.
BricsCAD Shape Interface - Joachim-s Journey -commandline classic-1024x146
Tips
BricsCAD Shape Interface - Joachim-s Journey -tips-1024x575
To the right-hand side of the interface, there is a box labeled 'Tips'. This gives a quick overview of some of the commands in BricsCAD Shape.
It also displays info while some commands are active.
Icons Strip
BricsCAD Shape Interface - Joachim-s Journey -strip-1024x575
On the far righthand side of the interface is the Icons Strip. This gives you instant access to the components, materials, layers, profiles and view style. I'll cover these in a later post.
LookFrom
BricsCAD Shape Interface - Joachim-s Journey -lookfrom-e1565617670687
Hovering in the top right-hand corner is the LookFrom widget. It's the navigation control in the upper right corner of the drawing window that lets you look at your model from different sides. Pass your cursor over the LookFrom tool and select the side from which you want to view your model.
To view from underneath hold ctrl.
Where Next?
I hope you enjoyed this brief exploration of the BricsCAD Shape User Interface. Join me next time when I will be showing you how to use some of the basic commands in BricsCAD Shape.
Download BricsCAD Shape Free
Watch the webinar "BricsCAD Shape in 10 minutes"
More CAD lessons:
  1. What is BricsCAD Shape?
  2. Download & Install
  3. Get started
  4. The Interface
  5. Commands
  6. Selecting Objects
  7. Transform
  8. Materials
  9. Components
  10. View Styles
  11. Layers
  12. Editing Entities
  13. More way to Edit Entities
  14. Arrays
  15. Dynamic User Coordinate Systems
  16. Export files and images
  17. Lazy Man's Guide to BricsCAD Shape
19 de marzo de 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10 de marzo de 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Síganos en las redes sociales
