2D Zeichnen
Tuesday Tips - Transform 2D Entities with Stretch
Von Rose Barfield 2 min 5. April 2021
If you're looking to transform and scale 2D entities non-uniformly, then you need STRETCH.
Use it to change the size and shape of 2D entities, with just a few clicks of the mouse.
Transform 2D Entities with Stretch- stretch 2
This is a 2D, isometric drawing, not a 3D model.
To stretch entities
  1. Enter the STRETCH command.
  2. Select a portion of the 2D entities to move.
  3. Select a base point and an endpoint.
    The selection should now be stretched.
    Note: To add or remove entities from the selection, you can use any selection method you would normally use.
Warning: This command only works in 2D.
Get a Grip
STRETCH isn't the only way to change the shape of a 2D entity; you can also manipulate entities using grips.Transform 2D Entities with Stretch- grips
How to modify a drawing with grips:
  1. Click the entity you want to modify. The entity grips display.
  2. Click a grip to activate it. The grip will change color.
    Tip You can change the color of grips in the settings dialog.
  3. Hold Shift to select multiple grips.
  4. Release Shift and move the selected grips.
    Tip This also works in 3D.
Download BricsCAD free for 30-days
Transform 2D entities with BricsCAD®
Permanent or subscription licenses that work in all languages and regions.
More Tuesday Tips:
19. März 2024 8 min
Neu in BricsCAD® V24.2
BricsCAD® V24.2 verfügt über viele neue und verbesserte Funktionen für 2D-Zeichnung, 3D-Modellierung, Civil, Vermessung, BIM und Mechanical Arbeitsabläufe. Das Bricsys-Team hat in diese Version mehrere neue Funktionen und Verbesserungen integriert, die Ihnen dabei helfen, die Lieferzeit zu verkürzen und Ihnen ein vertrautes CAD-Erlebnis bieten. Beginnen wir also mit der Erkundung der Neuerungen in BricsCAD V24.2!
10. März 2024 6 min
Der Weg zur Scan-to-BIM-Automatisierung mit BricsCAD® BIM V24
Die neuen Automatisierungstools in BricsCAD® BIM V24 machen den Scan-to-BIM-Prozess einfacher und effizienter! Wenn Sie eine schnelle und genaue Realitätserfassung vorhandener Objekte wünschen, sind diese Tools eine großartige Ergänzung Ihres Arsenals. Wir haben Tools wie den Punktwolken-Klassifikator, Punktewolke Räume erkennen, Punktwolke Räume anpassen und Normalen Berechnung für strukturierte Punktwolken hinzugefügt, die Sie bei der Erstellung digitaler Zwillinge für die Mengenabnahme, die Erstellung präziser Gebäudepläne und das Gebäudemanagement unterstützen.
Folgen Sie uns in den sozialen Netzwerken
