2D Zeichnen3D Modellierung
Discover the Difference: More Efficient CAD command with Blockify & Parametric Blocks
Von Gavin England 3 min 5. Oktober 2022
1_Blockify_Create_Block
In ‘BricsCAD: Discover the Difference’ today, we continue to look at the smart commands for users to enjoy more productivity. We explore how parametric blocks automates repetitive tasks and why creating either 2D or 3D block definitions in BricsCAD working with parametric constraints is intuitive and easy to use.
2_Blockify_Replace_Entities_with_Block
Blockify – parametric blocks for 2D and 3D drawings
When dealing with CAD drawings containing large numbers of common objects, blocks are a great way to make them more manageable. Normally, blocks must be individually defined, and common sets of entities manually replaced with the blocks you created. This can be frustrating and time consuming.
Blockify allows a block to be created from a set of 2D or 3D entities, and then it looks for similar sets of entities within the drawing (or a defined area) and automatically converts those to the same block.
Using the block command to define common objects has many benefits for users’ workflows. It reduces a drawing’s complexity, makes a drawing more manageable, and allows users to edit drawings quickly and easily.
3_Blocks_Parametric
Parametric blocks for the same entities
To make a block of entities, users can elect a set of entities using the Blockify command. Once the entity is created in a block, Blockify moves to the second step and automatically searches your chosen area or entire drawing for similar entities. It then applies the same block constraints to these entities.
Once Blockify has searched and replaced, you’ll notice that the drawing has far fewer entities, making it less complex and more manageable. And a process which was once time consuming and error-prone can now be completed in seconds.
4_Blocks_Guided_Insert
Parameterised geometry from 2D or 3D blocks
Once you have your blocks, users now have entities with the same parametric geometry in both 2D and 3D. This delivers entities with re-usable geometry which can be used many times in the drawing, in multiple sizes and orientations. As you work on the parameters, you can animate them to make sure they perform as expected, and use guided insert so the entity blocks adapt to the entities around them.
5_Blockify_Benefits
With Blockify and Parametric Blocks, you have the command tools to spend less time repetitive re-creating entities and re-use blocks in multiple different scenarios, quickly and easily.
Blockify and Parametric Blocks offer BricsCAD users productive tools through intelligent commands. We’ll be back next time with more ideas to free your time for design creativity - why not find out the BricsCAD difference for yourself? Download you free trial today.
Visit our migration page for more information on how easy it is to move to BricsCAD
von Gavin England - Product Marketing Manager
A qualified Mechanical Engineer, Gavin spent the early part of his career working in various design teams, helping to develop products as diverse as materials handling equipment and rally cars. The last twenty years have been spent in organisations such as IBM, Siemens and Autodesk, promoting and marketing CAD, PLM and related solutions, primarily to the manufacturing industry. An advocate of the benefits of innovate design technology, Gavin works in the Bricsys Go To Market team, focused on helping our customers understand the unique value of BricsCAD Pro, Lite and Mechanical, particularly within the manufacturing industry.
15. April 2024 3 min
BricsCAD® Pro V24.2 - Leistungsverbesserungen
BricsCAD V24.2 ist da und bringt eine Reihe von Leistungsverbesserungen mit, die eine Steigerung der Effizienz und Stabilität versprechen. Die neueste Version ist auf technische Zeichner, Designer und Hersteller aller Branchen zugeschnitten und konzentriert sich auf die Beschleunigung der Erstellung detaillierter Designdokumentation, die für Bau-, Fertigungs- und Herstellungsprozesse unverzichtbar ist. Sehen wir uns die Verbesserungen in V24.2 genauer an, die Ihre Lieferzeit verkürzen werden.
8. April 2024 4 min
Verbesserte Zeichnungskompatibilität in BricsCAD® V24.2
In V24.2 haben wir die DWG-Kompatibilität von BricsCAD weiter verbessert, um die schnelle Erstellung von Designdokumentation zu gewährleisten, indem wir uns auf den Arbeitsablauf zur Erstellung von 2D-Zeichnungen konzentrieren. Um eine reibungslose Zusammenarbeit zu gewährleisten, haben wir sichergestellt, dass Sie die in BricsCAD erstellten Zeichnungen in anderen DWG-basierten CAD-Programmen öffnen und bearbeiten können. Schauen wir uns die Verbesserungen an, die wir vorgenommen haben!
25. März 2024 4 min
Was ist neu in BricsCAD® Lite und Pro V24?
Im neuesten Update bietet BricsCAD® V24.2 viele neue und verbesserte Funktionen, um die Erstellung Ihrer 2D-Zeichnungen zu vereinfachen. Wir haben eine intuitivere Benutzererfahrung eingeführt, die Leistung und Stabilität verbessert und neue und verbesserte Funktionen hinzugefügt, um Ihre Produktivität weiter zu steigern. Diese Version bietet Arbeitsabläufe, die die Präzision und Vielseitigkeit ermöglichen, die Sie für den reibungslosen Ablauf Ihrer 2D-Zeichnen- und Designprojekte benötigen.
Folgen Sie uns in den sozialen Netzwerken
