3D Modellierung 2D Zeichnen BIM
BricsCAD® BIM V24: Quickest path to 3D from 2D
Von The Bricsys Team 5 min 14. Dezember 2023
With BricsCAD® BIM V24's new modeling tools, you can transition from a 2D plan to a 3D model and convert your design concepts into 3D representations quickly and easily! With V24, you can pull 2D plans into 3D to create solid objects, better identify structures and entities with Top View mode, and convert everything into a complete BIM project.
Let's walk through how you can go from 2D to 3D in a flash with BricsCAD BIM V24.
Attach 2D plan to 3D model in BricsCAD®
BricsCAD 2D plan to 3D model
When you receive a 2D plan from a designer, you can attach it to a 3D model, so when you receive an updated version, all you need to do is update the link. Once you have the plan attached, you can begin modeling!
Exterior Walls
External walls BricsCAD BIM
In this example, we start by adding exterior walls in Top View Mode. You can access Top View mode from the story bar. We used a poly wall with the wall tool, inserted the relevant details like height, thickness, and justification, and traced the walls with the simple snap-on.
Interior Floor Layout
BricsCAD BIM Slab tool floor
Now that our exterior walls are in place, we can move on to the floor. Using the new slab tool, you can easily create a floor slab. If you navigate the Home tab, you'll find easy access to model any shape you need. Select the slab tool, identify the justification, select all entities, and create the slab. Then, you can assign an offset to extend the slab under the external wall.
Automatic Boundary Detection for Columns
Boundary Detection Column BricsCAD BIM
BricsCAD's column tool supports most standard generic shapes for steel and concrete, and you can access them from the library. You can even choose a non-square profile and use boundary detection to identify the columns.
Interior Walls and Doors
Interior Wall BricsCAD BIM
To complete the interior floor's layout, you can add a single wall segment using the wall tool and choosing a single wall. You can assign an internal wall composition from the library. This tool recognizes wall thickness and gives you the option to automatically adjust its angle based on a 2D line. This smart behavior can also be used with point cloud data. You can swap the direction using the control button for a better interpretation. Then, you can use the BIM Extend tool to finish the wall.
Interior Doors BricsCAD BIM
Once you have finished with the walls, you can begin placing the doors and windows. You can change the visualization to see-through and see the 2D plan to fit the entities in the correct location. From the BricsCAD library, you can choose the doors that best fit your project, and the Quad makes it easy to flip the door or change its direction as needed.
Flip Door BricsCAD BIM
IFC Classification in BricsCAD®
IFC Classification BricsCAD BIM
BricsCAD allows you to either start with known materials and predefined parameters, or with only the geometry. Our automatic classification carries out the IFC classification on all elements - speeding up your process further.
New Roof Tool in BricsCAD® BIM V24
Roof BricsCAD BIM
The QUICKDRAW command allows you to create more floors with the same shape and content, or only create the external walls, and place the final slab for the roof. You can stick to a flat roof, or if you want to use a standard roof shape like a gable, or M-shape you can use the new roof tool to quickly insert the roof you need.
M Shape Roof BricsCAD BIM
In BricsCAD BIM V24, we have added building modeling tools that are familiar, easy to use, and smart when needed. You can move from a 2D plan to a 3D model quickly to visualize your design concepts more tangibly and identify potential design flaws, clashes, or ways to improve the process.
Watch the tutorial!
To follow along with a video tutorial, you can watch this session on the Bricsys YouTube channel.
There's plenty more in BricsCAD BIM V24, so watch our Breakout Sessions for an in-depth look at some of these new features!
Want to learn more about BricsCAD® V24?
If you're curious about what else you can do in BricsCAD V24, check out our YouTube channel or take a peek at the rest of the Bricsys blog to learn more!
Have you used BricsCAD® V24 and have some ideas or suggestions?
Fantastic! We love hearing your thoughts on BricsCAD® – all feedback is welcome, whether good or bad. The best way to tell us what you think about BricsCAD is to send us a support request; our support team will gladly help.
Get started with BricsCAD® V24 today!
Buy BricsCAD or download the 30-day free trial now and discover how you can accelerate your time to deliverable with BricsCAD.
7. Dezember 2023 4 min
BricsCAD® V24: Eine moderne Benutzererfahrung
Wenn Sie ein CAD-Benutzer sind, der kürzlich auf BricsCAD umgestiegen ist, kann die Gewöhnung selbst an geringfügige Unterschiede Ihre Arbeit verlangsamen. Um Ihnen den Umstieg zu erleichtern, haben wir produktinterne Anleitungen direkt in BricsCAD hinzugefügt. Auf unserer neuen und verbesserten Startseite können Sie ganz einfach Vorlagen auswählen. Außerdem erhalten Sie eine Liste der zuletzt geöffneten Zeichnungen und die Option, zuletzt verwendete Dateien oben in Ihrer Liste anzuheften.
16. November 2023 5 min
BricsCAD® V24: Was ist neu in BricsCAD® BIM?
Mit BricsCAD® BIM V24 wollten wir Ihnen die Werkzeuge zur Verfügung stellen, die Sie benötigen. Viele unserer Anwender erhalten 2D-Zeichnungen von Designern für mindestens 40% bis 50% ihrer Projekte, so dass sie ihre 2D-Zeichnungen in 3D- und BIM-Modelle zur Visualisierung, Koordination, Planung und Mengenabnahme umwandeln müssen. Diese Konvertierung wird mit den Werkzeugen von BricsCAD BIM V24 vereinfacht, die einfach zu bedienen, vertraut und bei Bedarf intelligent sind.
2. November 2023 9 min
BricsCAD® V24: Was ist neu in Lite und Pro?
Willkommen bei BricsCAD® V24 - der leistungsstarken, effizienten und einfach zu bedienenden CAD-Software, die entwickelt wurde, um Ihren Arbeitsablauf zu rationalisieren und Ihre Zeit bis zur Fertigstellung zu verkürzen. BricsCAD® V24 ist schneller und effizienter als frühere Versionen von BricsCAD® und außerdem benutzerfreundlicher, was es zum perfekten Werkzeug für neue und erfahrene CAD-Benutzer macht. Diese Version enthält Funktionen und Verbesserungen für BricsCAD® Lite und BricsCAD® Pro, um Ihre täglichen Arbeitsabläufe zu automatisieren und zu optimieren. Schauen wir uns an, was es Neues für BricsCAD® Lite und BricsCAD® Pro in V24 gibt!
Folgen Sie uns in den sozialen Netzwerken
