2D kreslení
What is CAD/CAM? - Back to Basics?
Podle Rose Barfield 2 min 27. ledna 2021
What is CAD/CAM?
What is CAD/CAM? What does it stand for? What is computer-aided manufacturing and what has it got to do with CAD software? Keep reading to find out.
What does CAD/CAM stand for?
CAD/CAM is a combination of two acronyms:
CAD
Computer Aided Design   or   Computer Aided Drafting
CAM
Computer-Aided Manufacturing or   Computer-Aided Modeling   or   Computer-Aided Machining
The most common is Computer-Aided Manufacturing.
What is Computer-Aided Manufacturing?
Computer-Aided Manufacturing simply means any type of manufacturing that is created with the "aid" of a computer. This can be anything from the act of using a computer to control a machine that manufactures parts, to the use of a computer to assist in the management of a manufacturing plant.
CAM includes manufacturing techniques such as additive manufacturing (3D printing), laser cutting and computer numerical control (CNC) machining.
What is CADCAM- 3d printing
3D printing is a type of CAM
What is CAD/CAM?
CAD/CAM means literally: Computer-Aided Design & Computer-Aided Manufacturing. Both CAD and CAM are required to manufacture a part, it is unusual, although not impossible, to find one without the other. Generally, a part is first designed in a piece of CAD software and then sent to a CAM software package for manufacture.
What is CAM software?
CAM software is any software package that translates a CAD model into a language that the machine can understand. It tells the machine how to manufacture the part. Some software packages do both CAD and CAM.
More Back to Basics:
19. března 2024 8 min
What's New in BricsCAD® V24.2
BricsCAD® V24.2 is chock full of new and enhanced features for 2D drafting, 3D modeling, civil, survey, BIM, and mechanical workflows. With this release, the Bricsys team included several new features and improvements to help you accelerate your time to deliverable and provide you with a familiar CAD experience. So, let's dive in and explore what's new in BricsCAD V24.2!
10. března 2024 6 min
The path to Scan to BIM automation with BricsCAD® BIM V24
The new automation tools included in BricsCAD® BIM V24 make the Scan-to-BIM process easier and more efficient! If you want fast and accurate reality capture of existing objects, these tools will be a great addition to your arsenal. We've added tools like the Point Cloud Classifier, Point Cloud Detect Rooms, Point Cloud Fit Rooms, and Normal Calculation for structured point clouds to help you create digital twins for quantity takeoff, create accurate building plans, and with facility management.
Sledujte nás na sociálních médiích
