Looking for BricsCAD tutorials? If you're new to BricsCAD you might be wondering where to start. The good news is that BricsCAD has tailored lessons, tutorials and a great Help Center for everyone, regardless of your starting level.
2D tutorials
You can follow our free lessons here.
Work through all the lessons to get your 2D drafting up to speed. Cover the basics from the interface, drawing tools, annotating and layout printing. Each lesson contains a short 2-5 minute video, a complete set of written instructions, and there are downloadable files to work with. All completely free!
BricsCAD Core lessons
Learn BricsCAD Core. Whether you're looking for a way to customize the background, learn the secrets of the shift key, use roaming licensing or simply loft 3D surfaces, we've got you covered.
BIM
Add BIM data to your design with BricsCAD BIM tutorials. Learn how to create wall layouts, create a grading and use the window creator tool.
Mechanical
Get technical with BricsCAD Mechanical tutorials. Learn how to use mass properties, parametrize sheet metal, and even work with inverse kinematics.
Shape
Learn BricsCAD Shape in half an hour. Follow through the short videos to take you from CAD beginner, to Shape master.
Switching to BricsCAD from another platform?
Follow along with Heidi's Journey into BricsCAD, she takes you through her step by step guide for users making the move to BricsCAD. Why not start with 23 tips to accelerate your BricsCAD Journey?
Still searching?
Check out our Help Center, where there is information on every command available in BricsCAD, or head over to our YouTube channel and discover even more BricsCAD videos, demos, tips, and tricks.
