Automatically load the SDS™ application when one of its commands is used.
This function returns associates a list of command names with an application name. Then, when the user types a command name, Bricscad searches for and loads the associated SDS file.
Example
| Code | Returns |
| (autoxload "routine" '("start" "run" "stop")) | nil |
Tell me about...
Programming Overview of LISP (LISt Processing) Language
